Bridging solution ???
thisisshanky Mon, 02/24/2003 - 18:06
  • Purple, 4500 points or more
Configure a trunk between 4006 and external router, to trunk both the vlans. Configure two subinterfaces on the fast ethernet int. of router one each for each vlan. I assume the vlans in your case as 10 and 20.
The router configurations would look somewhat like this....
int fa0/1.10
encapsulation isl 10
description vlan 10
bridge-group 1
int fa0/1.20
encapsulation isl 20
description vlan 20
bridge-group 1
bridge 1 protocol ieee.
On the port on catalyst connecting to router, configure a trunk using command "set trunk"
Hope that helps!
Hi Sankar Nair,
Thank very much for your support me, and now I have proplem on catalyst 4006 and AT 8324SX Allied Telesyn:
Configuring port on catalyst 4006 using trunk mode and 802.1q encapsulation as below:
interface FastEthernet2/35
switchport mode trunk
duplex full
no snmp trap link-status
Configuring fastethernet port on AT8324 switch using trunk mode (configure by user graphic interface mode).
But i don't understand, the trunk line didn’t work
Can you check configuration on catalyst 4006?
Best regards
Manh Hung
thisisshanky Mon, 02/24/2003 - 21:55
The configs on the cat do look fine.
See if you did give a "no shutdown" on the port fa2/35. (this might not be needed, as "shutdown" is not there under the interface in your configs)
CHeck the trunking status.... Try "show interfaces fastethernet 2/35 switchport" or "show interfaces fastethernet 2/35 trunk "
It could also be a problem with the AT 8324 external router configuration.
raarons Wed, 02/26/2003 - 08:10
If memory serves me right, the AT switch automatically tags all traffic on the trunk link. The 4006 does not tag the native vlan, which is vlan 1 (by default) in your configuration. Therefore I would not expect vlan 1 to operate between the router and switch as configured. If this is your problem, the solution is to set another unused vlan as the native vlan on the 4006, so that vlan 1 becomes tagged...
switchport access vlan 999 !!!! vlan 999 is unused
duplex full
This should provide continuity in vlan 1 between Cisco and AT switches.
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Further, due to recent implimentation of posting size restrictions, the post has been cut in half and the remaining post is in a new message below by ciscomoderator. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
To day I go to my factory and configuring Catalyst 4006 and AT8324 follow
your instruction but the trunking line still doesn't work.I changed
configuration as access mode the system work propely.
Pls help me checking my configuration.
AT8324 switch confiruration
System Information
System Description : AT-8324SX, version 1.402
System Object ID : 1.3.6.1.4.1.207.1.4.42
System Up Time : 247523 (0 day 0 hr 41 min 15 sec)
System Name : CentreCOM AT-8324SX
System Contact : DEFAULT SYSTEM CONTACT
System Location : DEFAULT SYSTEM LOCATION
Switch Information : Unit 1
Main Board
Hardware Version : V4.0
Firmware Version : V1.11
Serial Number : 00-30-84-03-73-E0
Port Number : 26
Internal Power Status : Active
Redundant Power Status : Inactive
Expansion Slot 1 : 2Port 100Base-FX(MMF)
Expansion Slot 2 : Stacking
Agent Module
Hardware Version : V2.0 (801 CPU)
POST ROM Version : V1.11
Firmware Version : V1.402
SNMP Agent : Master
Port Configuration : Unit 1 Port 1 - 12
Flow Control on all ports : [Enable] [Disable]
Port Type Admin Flow Control Speed and Duplex
1 10/100TX ENABLED DISABLED AUTO
2 10/100TX ENABLED DISABLED AUTO
3 10/100TX ENABLED DISABLED AUTO
4 10/100TX ENABLED DISABLED AUTO
5 10/100TX ENABLED DISABLED AUTO
6 10/100TX ENABLED DISABLED AUTO
7 10/100TX ENABLED DISABLED AUTO
8 10/100TX ENABLED DISABLED AUTO
9 10/100TX ENABLED DISABLED AUTO
10 10/100TX ENABLED DISABLED AUTO
11 10/100TX ENABLED DISABLED
Port Configuration :Unit 1 Port 25 - 32
25 100FX ENABLED DISABLED 100_FULL
26 100FX ENABLED DISABLED 100_FULL
27 -------- --------- ------------- ---------
28 -------- --------- ------------- ---------
29 -------- --------- ------------- ---------
30 -------- --------- ------------- ---------
31 -------- --------- ------------- ---------
32 -------- --------- ------------- ---------
Port Information : Unit 1 Port 1 - 12
Port Type Operational Link FlowControl Speed and
InUse Duplex InUse
1 10/100TX YES UP NONE 100_FULL
2 10/100TX YES DOWN -------------- ----------
3 10/100TX YES DOWN -------------- ----------
4 10/100TX YES DOWN -------------- ----------
5 10/100TX YES DOWN -------------- ----------
6 10/100TX YES DOWN -------------- ----------
Port Information : Unit 1 Port 25 - 32
InUse Duplex InUse
25 100FX YES DOWN -------------- ----------
26 100FX YES UP NONE 100_FULL
27 -------- --- ----- -------------- ----------
28 -------- --- ----- -------------- ----------
29 -------- --- ----- -------------- ----------
30 -------- --- ----- -------------- ----------
31 -------- --- ----- -------------- ----------
32 -------- --- ----- -------------- ----------
802.1Q VLAN Base Information
VLAN Version Number : 1
MAX VLAN ID : 2048
MAX Supported VLANs : 256
Current Number of 802.1Q VLANs Configured : 3
802.1Q VLAN Current Table Information
Deleted VLAN Entry Counts : 0
VID Creation Time Status
1 0 (0 day 0 hr 0 min 0 sec) Permanent
Unit Current Egress Ports Current Untagged Ports
1. 001111111111 111111111111 11-- 001111111111 111111111111 11--
2. ------------ ------------ ---- ------------ ------------ ----
3. ------------ ------------ ---- ------------ ------------ ----
4. ------------ ------------ ---- ------------ ------------ ----
Sorted by VID : 1
[Show] [More]
802.1Q VLAN Static Table Configuration
VID VLAN Name Status
1 Active
Unit Egress Ports Forbidden Egress Ports
1. 001111111111 111111111111 11-- 000000000000 000000000000 00--
Unit Untagged Ports
1. 001111111111 111111111111 11-- VID : 1
2. ------------ ------------ ---- [Show]
3. ------------ ------------ ---- [More]
4. ------------ ------------ ---- [New]
The name of the VLAN. | R
Port Trunking Configuration
Trunk ID Status Member List
1 2 3 4
1 ENABLED Unit : 1 Unit : - Unit : - Unit : -
Port : 26 Port : -- Port : -- Port : --
-- -------- Unit : - Unit : - Unit : - Unit : -
Port : -- Port : -- Port : -- Port : --
Trunk ID : 1 Trunk ID : 1 Member Unit : 1
Member Port : 1
[Show] [More]
802.1Q VLAN Port Configuration : Unit 1 Port 1 - 12
Port PVID Acceptable Ingress GVRP GVRP Failed GVRP Last
Frame Type Filtering Status Registrations PDU Origin
1 2 All TRUE DISABLED 0 00-00-00-00-00-00
2 2 All TRUE DISABLED 0 00-00-00-00-00-00
3 1 All TRUE DISABLED 0 00-00-00-00-00-00
4 1 All TRUE DISABLED 0 00-00-00-00-00-00
5 1 All TRUE DISABLED 0 00-00-00-00-00-00
6 1 All TRUE DISABLED 0 00-00-00-00-00-00
[Enable] [Disable] [Add] [Delete]
802.1Q VLAN Port Configuration : Unit 1 Port 25 - 32
25 1 All TRUE DISABLED 0 00-00-00-00-00-00
26 1 All TRUE DISABLED 0 00-00-00-00-00-00
27 ---- --- ----- -------- ---- ---------------
Cisco Cattalyst 4006 configuration
urrent configuration : 5460 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname FAPV4006
boot system bootflash:cat4000-is-mz.121-8a.EW1.bin
no logging console
enable secret 5 $1$t69v$VZHoZRl48Wb5xLRKxb20G/
ip subnet-zero
no ip domain-lookup
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface FastEthernet2/1
switchport access vlan 3
switchport mode access
duplex full
speed 100
interface FastEthernet2/2
duplex full
speed 100
duplex full
speed 100
interface FastEthernet2/4
duplex full
interface FastEthernet2/5
duplex full
speed 100
interface FastEthernet2/6
duplex full
interface FastEthernet2/7
duplex full
speed 100
interface FastEthernet2/8
duplex full
speed 100
interface FastEthernet2/9
duplex full
interface FastEthernet2/10
duplex full
interface FastEthernet2/11
duplex full
interface FastEthernet2/12
duplex full
speed 100
interface FastEthernet2/13
duplex full
speed 100
-- continued in post by ciscomoderator below --
ciscomoderator Wed, 03/26/2003 - 12:55
  • Gold, 750 points or more
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
interface FastEthernet2/14
duplex full
speed 100
interface FastEthernet2/15
duplex full
speed 100
interface FastEthernet2/16
duplex full
speed 100
interface FastEthernet2/17
duplex full
speed 100
interface FastEthernet2/18
duplex full
speed 100
interface FastEthernet2/19
duplex full
speed 100
interface FastEthernet2/20
duplex full
speed 100
interface FastEthernet2/21
duplex full
speed 100
interface FastEthernet2/22
duplex full
speed 100
interface FastEthernet2/23
duplex full
speed 100
interface FastEthernet2/24
switchport access vlan 4
duplex full
speed 100
interface FastEthernet2/25
duplex half
interface FastEthernet2/26
duplex half
interface FastEthernet2/27
duplex half
interface FastEthernet2/28
duplex half
interface FastEthernet2/29
switchport access vlan 2
duplex half
interface FastEthernet2/30
duplex half
interface FastEthernet2/31
duplex half
interface FastEthernet2/32
switchport access vlan 7
duplex full
speed 100
interface FastEthernet2/33
duplex full
interface FastEthernet2/34
duplex full
duplex full
interface FastEthernet2/36
duplex full
interface Vlan1
ip address 10.190.1.1 255.255.255.0
interface Vlan2
ip address 10.190.11.1 255.255.255.0
interface Vlan3
ip address 10.190.12.1 255.255.255.0
interface Vlan4
ip address 10.190.13.1 255.255.255.0
interface Vlan7
ip address 10.190.10.1 255.255.255.0
router rip
network 10.0.0.0
ip classless
ip route 10.192.11.0 255.255.255.0 10.190.11.5
no ip http server
line con 0
password 7 --moderator edit--
login
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
FAPV4006#e
sh command
FAPV4006#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa2/34 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa2/34 1-1005
Port Vlans allowed and active in management domain
Fa2/34 1-4,7,1002-1005
Port Vlans in spanning tree forwarding state and not pruned
FAPV4006#sh int fa2/34 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
FAPV4006#sh vlan
VLAN Name Status Ports
1 default active Gi1/1, Gi1/2, Fa2/33
2 VLAN2 active Fa2/29, Fa2/30, Fa2/31, Fa2/35
3 VLAN3 active Fa2/1, Fa2/2, Fa2/3, Fa2/4
Fa2/5, Fa2/6, Fa2/7, Fa2/8
Fa2/9, Fa2/10, Fa2/11, Fa2/12
Fa2/13, Fa2/14, Fa2/15, Fa2/16
Fa2/17, Fa2/18, Fa2/19, Fa2/20
Fa2/21, Fa2/22, Fa2/23
4 VLAN4 active Fa2/24, Fa2/25, Fa2/26, Fa2/27
Fa2/28, Fa2/36
7 VLAN7 active Fa2/32
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Primary Secondary Type Ports
Thank you very much
Hung
farshid_sh Thu, 03/27/2003 - 05:40
Hi there
i am not an expert in networking
but i gusse the problem is the encap mismatch
set both the switch and router to ISL encap
that may aolve the problem
good luck
easyzjj Thu, 12/18/2003 - 04:18
you just need adding a cross-over ethernet cable to one port belonging to both vlans.....
