sending traffic from one dial-peer to multiple gateways
nmilojevic
Hi!
I have following situation; two locations, 1 * AS5350 on first and 2 * 5300 on other. All GWs are regged to one GK. How do I convince dial-peer on 5350 to send traffic to 2nd 5300, when 1st is full? (on 5350 voip dial-peer, I have "session target ipv4:A.B.C.D", it doesn't work with "session target ras" ?why?).
Furthermore, one neighbouring zone is also sending me some traffic for 2nd location (one with 2 * 5300).
Any suggestions, please!
Nikola
s.jankowski
Level 4
Level 4
This document has the configuration commands for the multiple gateways.This should help you.
H.323 Version 2 Support
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087a41.html#xtocid19
