Warning message
HSSI Line Protocol Issues..
Below is a output from the known working router (3600). I don't have a problem with this router but I need this router replaced with a Cisco 6509 Multilayer switch with a HSSI card. The problem I have is when I swap the connections for the 6509 from the 3600, I get line line protocol despite having the exact same config as the 3600. Why doesn't the same config parameters work on the 6509. From my experience I have noticed that line protocol issues usually deal with HArdware and Cabling. I am leading to the right path?
Hssi0/1 is up, line protocol is up
Hardware is M1T-HSSI-B
Interface is unnumbered. Using address of FastEthernet0/0
MTU 4470 bytes, BW 45045 Kbit, DLY 200 usec,
reliability 255/255, txload 2/255, rxload 38/255
Encapsulation HDLC, crc 32, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d1h
Queueing strategy: fifo
Output queue 0/40, 5 drops; input queue 0/75, 0 drops
5 minute input rate 6831000 bits/sec, 754 packets/sec
5 minute output rate 365000 bits/sec, 336 packets/sec
8952007 packets input, 2216731701 bytes, 0 no buffer
Received 17668 broadcasts, 1 runts, 2 giants, 0 throttles
0 parity
10 input errors, 9 CRC, 0 frame, 1 overrun, 0 ignored, 0 abort
7106905 packets output, 1538610945 bytes, 0 underruns
0 output errors, 0 applique, 1 interface resets
3 carrier transitions LC=down CA=up TM=down LB=down TA=up LA=down
donewald Mon, 02/24/2003 - 09:22
  • Silver, 250 points or more
What type PA are you installing in your Catalyst? Can you also put the configuration (interface specific) that you are trying to apply to this PA that is not working?
Don
