Warning message
Clock time on 801 Router
Feb 24th, 2003
I can set the time on the router, but, when I reboot the time has reverted to it's original time. Isett the time in enabled mode and use the command, "copy running startup" to sve the changes. Any pointers would be much appreciated.
Gerard
Overall Rating: 5 (1 ratings)
thisisshanky Mon, 02/24/2003 - 09:49
  • Purple, 4500 points or more
That clock you set is never saved. Every time you reboot, it will revert back to Mar 1 1993. You could use NTP to syncrhonize the time in the router with a NTP Server.
