Warning message
4506 SUP-4 Bridging configuration
Feb 25th, 2003
Hello.
Can I configure bridging on the 4506-SupIV ?
I need to configure some interfaces with ip-address and bridging between them ,
Can I do it ?
How?
Boaz.
b.shoresh Tue, 02/25/2003 - 23:21
Hello.
Thank you for the reply.
Any idea why doesn't it support bridging (L3 card with the SUPII does support it) ?
Any idea if and when will it support bridging ?
Thank you,
Boaz.
bsivasub Wed, 02/26/2003 - 21:57
Sup3/4 is a newer Supervisors and is designed for HW forwarding of IPv4 packets upto 48Mpps. Bridging even if supported would be through software switching path and not as nearly as high performance as ipv4 switching.
We can't comment on future support of this feature at this time.
Refer to the following URL for some alternate solutions
http://www.cisco.com/warp/customer/473/182.html
