Warning message
801 with ISDN problems
Hi all,
I am having some problems with my configs for my routers, its a problem that has only recently occured and appears to be ios independant, although I can't guarantee it.
I can put the config in the router and all will work fine however if I reboot the router fails to connect. A show isdn stat says layer 2 is not activated. If I unplug and replug the isdn it works again. This has happened at at least 4 sites so the isdn supply is unlikely to be the issue, as is the actual router as I have tried 6 so far that show this problem. It usually occurs with the original IOS so I try upgrading to c800-y6-mw.122-13a.bin but this makes no difference.
I get the same issue if I use faststep as well.
I have included the config and a copy of what happens when I unplug and replug the isdn at the bottom.
I would really appreciate anyones help on this,
cheers for your time.
Andy
clock set 11:12:00 25 February 2003
config t
enable password password
enable secret pencil
hostname router
boot system flash c800-y6-mw.122-13a.bin
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
time range
periodic daily 05:30 to 20:00
end
config terminal
map-class dialer DialClass
access-list 18 permit 192.168.2.0 0.0.0.255
access-list 121 deny udp any eq netbios-dgm any
access-list 121 deny udp any eq netbios-ns any
access-list 121 deny udp any eq netbios-ss any
access-list 121 deny tcp any eq 137 any
access-list 121 deny tcp any eq 138 any
access-list 121 deny tcp any eq 139 any
access-list 121 permit ip any any time-range TIME
dialer-list 1 protocol ip permit
interface e0
ip address 192.168.2.5 255.255.255.0
ip access-group 121 in
no ip proxy-arp
ip nat inside
no shutdown
interface bri0
no ip address
encapsulation ppp
dialer pool-member 1
ppp authentication chap pap callin
no shutdown
int dialer1
ip address negotiated
no ip proxy-arp
ip nat outside
encap ppp
no ip split-horizon
dialer pool 1
dialer idle-timeout 60
dialer string telnumber class DialClass
dialer-group 1
ip nat inside source list 18 interface dialer1 overload
interface dialer1
ppp chap hostname username
ppp chap password password
ppp pap sent-username username password password
no shut
end
config terminal
ip route 0.0.0.0 0.0.0.0 dialer1
end
router#ping 158.152.1.58
Sending 5, 100-byte ICMP Echos to 158.152.1.58, timeout is 2 seconds:
Success rate is 0 percent (0/5)
00:01:33: BRI0 : start_t4 - timer T4 already running
00:01:33: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 64 changed to up
lgijssel Tue, 02/25/2003 - 06:04
  • Red, 2250 points or more
Try to add the global command:
isdn tei neg first
This might be a solution. We use this on all ISDN routers and we never have the problem you describe.
Leo
Thanks for the reply.
The command is slightly different on the ios I am running now "isdn tei first-call" but it didn't seem to help I still have the same problem.
I have now also found that the problem occurs like this:
Power off reboot - all works fine
Soft reboot - no outbound connection
This happens on multiple routers, and on IOS c800-y6-mw.121-17.bin, c800-y6-mw.121-18.bin, c800-y6-mw.122-13a.bin and c800-y6-mw.122-8.bin as far as I know. Im kinda stumped!
All works fine for my customers until they soft reset!
cheers
Andy
lgijssel Tue, 02/25/2003 - 11:07
OK, I have another one that might apply. You are doing something with the clock, probably to allow connections only on specified times. After a soft reset, the clock settings are gone and you start again at 0:00:00. In your config the ISDN is blocked during this time, it will take until 05:30 (or 5,5 hours uptime) before the clock reaches a valid time for ISDN to activate. Did you check what happens when you change this?
To make this work, you would need to configure ntp to set the clock. The ntp source should not be on the remote side of the ISDN link, otherwise you will have long uptimes.
Leo
