Warning message
Broken TCP conn. on PIX site-to-site VPN
Feb 25th, 2003
I'm using 2 PIX-525's with VACs to establish a VPN between 2 cities using our internet provider (SURFnet) and Gb-ethernet links.
At random moments users who have an estabilished TCP connection to a MS Terminal server (RDP) are disconnected (2-3 times a day). They can reconnect directly but is seems that the standing TCP connections are broken. I configured al timers en keep-alives quite basic/default.
Anyone any ideas ?
pradeepde Mon, 03/03/2003 - 13:11
  • Bronze, 100 points or more
Some of the earlier versions of PIX OS used to send out a reset on seeing ip header with a bad checksum, thus resulting in sessions getting dropped at times. I believe this problem of reset TCP connections was fixed in PIX OS version 5.1.something. I guess the problem is most likely that you are running one of these older OS versions.
