Cannot load the record applet
Feb 26th, 2003
  • Cisco Employee,
logging into a fresh install of Unity 4.0 with IE 6SP1. For some reason, the recording applet isn't downloading and installing. Instead I have a big red X there. I have lowered the security on the browser to the lowest rating. Does anyone have any ideas?
lindborg Wed, 02/26/2003 - 14:37
  • Cisco Employee,
you may need to toast the CAB and have it download again now that you have the security lowered (or more to the point have allowed ActiveX controls). To do this you can delete the "AVMediaMasterCtrlCLass" file under the WinNT\Downloaded Program Files\ directrory and then reload the page - this should force it to download again and you'll see the "do you trust us" certificate thingy again and hopefully that'll fix you up.
cfortanb Mon, 03/03/2003 - 05:30
  • Cisco Employee,
That was it. Looks like IE6 installs with higher security.
