Warning message
Changeing providers, complicated NAT
I am brainstorming on this wondered if anybody had any ideas on it.
Cisco 2600 with working Internet Connection, switched Internetproviders, and for the short term to wait on DNS to propogate, I would like for both connections to be up and on the Internet, yet I would need for two NAT pools to be running and know to route at the Interface that it recieved the packet on.
I have looked at the Route map ispnat, type of setup but haven't used it. Wondered if anybody had any feedback on it.
Also, I see how this would work with say a 2600 with 2 wic's although could this be done on 2 2600's with 1 wic, keeping in mind that the default gateway will only be set to 1 of them.
Thanks in advance, the config I am thinking of useing one router is simular to below.
ip nat inside source static 11.1.1.2 192.68.1.21 route-map isp2
ip nat inside source static 11.1.1.2 172.68.1.21 route-map isp1
ip nat inside source static 11.1.1.1 192.68.1.11 route-map isp2
ip nat inside source static 11.1.1.1 172.68.1.11 route-map isp1
access-list 101 permit ip 11.1.1.0 0.0.0.255 172.0.0.0 0.255.255.255
access-list 102 permit ip 11.1.1.0 0.0.0.255 192.0.0.0 0.255.255.255
route-map isp2 permit 10
match ip address 102
set ip next-hop 192.68.1.1
route-map isp1 permit 10
match ip address 101
set ip next-hop 172.68.1.1
j-block Wed, 03/05/2003 - 14:20
If you would like to use two separate NAT pools for each ISP, a route-map can be used to choose the appropriate global address. In the route-map you can match both on the inside local addess as well as the next-hop address of ISP1 or ISP2 to which the packet is going to be forwarded and then translate it by linking the route-map to the pool configured with the address given by the corresponding service provider. There is a similar example in the Ciscopress book Routing TCP/IP vol.II by Jeff Doyle The syntax of your NAT configuration seems to be wrong. You cannot use a static translation for this. You need to use the 'ip nat inside source route-map ...." commands. Check if this link helps you :
http://www.cisco.com/warp/public/105/nat_routemap.html
