No Routing Table
Mar 3rd, 2003
Here is the situation
i have one 3620 in one office A, and another 3620 in another B, problem i can do a sh ip route on one router Aand see routing table of other router, but no routing table information on Router B, have looked at the configuration over and over again all looks fine, contacted Vendor of T1 line , they say line is okay,, any ideas
a.manosca Mon, 03/03/2003 - 17:26
  • Bronze, 100 points or more
Are you using static or dynamic routing?
If you're using static, you should be able to see entries in the
routing table even if the link is down.
For dynamic routing, should you verify the correct process being run, or the same
AS number being used. For example, in EIGRP, you should be using the
same AS number for both routers.
thisisshanky Mon, 03/03/2003 - 17:32
  • Purple, 4500 points or more
Check if you have ip routing disabled. Check if "no ip routing" has been entered in the configuration. If yes, you need to reenable it using "ip routing" command.
Since you are using a t1 line, check the status of your t1 interface. give a "show interface serial 0 " (use appropriate interface number) and find if the serial interface is up and the line protocol is also up.
Is the service provider, able to loop the CSU/DSU . Are you using external or internal CSU/DSU ??
gkiboneka Mon, 03/03/2003 - 18:04
the seril interface is up, line protocol is up, and the service provider can loop both CSU/DSU,which are internal
i am puzzled
gkiboneka Mon, 03/03/2003 - 18:02
dynamic Routing,, smae routing process, all the interface are up, line protocol up
ji.xie Mon, 03/03/2003 - 18:08
If you are convient,you can paste the output of show ip route here .
kapishmohole.cisco Wed, 03/05/2003 - 00:09
Can you post running config of both routers and output of sh ip route of both routers?
