03-04-2003 03:46 AM - edited 03-02-2019 05:33 AM
Hello Everyone,
The available technical notes do not explain neither how the reflector port should be configured nor what VLAN should it belong to.
Additionally: should the RSPAN dedicated vlan be configured explicitly as:
Switch(config-vlan)#remote-span
to work properly?
Thanks in advance for potential answers.
Rgds
Adam
03-04-2003 07:57 PM
Adam,
The following link answers all your questions:
Yes, it is recommended to have a dedicated VLAN for RSPAN, also in the above URL.
Hope this helps you,
Don
03-05-2003 01:03 AM
Don,
Thanks for unswer
Unfortunately, it does not help. I have read this doc several times and is not enough neither to understand nor to configure.
I read in command reference (remote-span command) that this cmd specifies the vlan characteristics. There is no info in config guide about this cmd.
Reflector-port: how does it happen for this port to forward traffic into RSPAN vlan? Should I add this port to the RSPAN vlan?
Adam
