Warning message
tftp broadcasts
7rbowenii Wed, 03/05/2003 - 13:06
Default setting for some switches is to broadcast through the network for their config file. This is contolled by the configuration registry. If you do a sho ver on your switch, the conf reg value will be displayed near the bottom. Post this, and we can check to see if this is the problem.
-Bo
7rbowenii Thu, 03/06/2003 - 12:22
The conf reg appears correct. I would check the caveats of the code you are using/going to use to determine whether or not this is a reported issue.
-Bo
