VPN Client "Allow local LAN Access"
Mar 5th, 2003
I have the above box check on the VPN Client software (Ver 3.5.1) but when I connect I am unable to access anything on my network and when I look at the general tab, the client software says that Local LAN access is disabled. Any ideas on how I can fix this?
afakhan Fri, 03/07/2003 - 14:41
  • Bronze, 100 points or more
This feature needs to be configured on the Headend(VPN3000) side first, go to :
Configuration->User Mgmt->Group Mgmt->Modify Group->Client Config tab, and then configure:
Tunnel everything (Select this radio button)
Allow the networks in list to bypass the tunnel (check this box)
and then under "Split Tunneling Network List", select :
VPN Client Local LAN (Default)
and reconnect your client, it should work.
Thx
Afaq
