Warning message
AP 350 restarts fec0 driver constantly
Mar 6th, 2003
Why does a 350 access point stop and start the fec0 driver so often? Sysloging to a unix system.
Mar 6 16:25:36 (Info): Stopped driver for port "fec0"
Mar 6 16:25:36 (Info): Started driver for port "fec0"
Mar 6 16:28:38 (Info): Stopped driver for port "fec0"
Mar 6 16:28:38 (Info): Started driver for port "fec0"
Mar 6 16:29:54 (Info): Stopped driver for port "fec0"
Mar 6 16:29:54 (Info): Started driver for port "fec0"
Mar 6 16:32:11 (Info): Started driver for port "fec0"
Mar 6 16:35:43 (Info): Stopped driver for port "fec0"
Mar 6 16:35:43 (Info): Started driver for port "fec0"
Mar 6 16:36:59 (Info): Stopped driver for port "fec0"
Mar 6 16:36:59 (Info): Started driver for port "fec0"
Mar 6 16:42:33 (Info): Stopped driver for port "fec0"
Mar 6 16:42:33 (Info): Started driver for port "fec0"
Mar 6 16:43:49 (Info): Stopped driver for port "fec0"
Mar 6 16:43:49 (Info): Started driver for port "fec0"
ndoshi Thu, 03/06/2003 - 22:22
  • Cisco Employee,
Hi ,
Are you able to pass traffic over ethernet port ?
What you have at other end of the AP ? Is that switch or hub ?
Can you try hard coding speed on to 10 or 100 on AP and see if it goes away ?
If opposite end device in non cisco , try disabling the CDP .
Nilesh
ndoshi Thu, 03/06/2003 - 23:20
  • Cisco Employee,
a) Make sure you are running latest firmware on AP
b) if you go to ethernet -> advance
optimize ethernet for --- select "performance"
c) It seems cosmetic issue , check ether stats , counters anything unusual ?
Nilesh
thammerle Fri, 03/07/2003 - 05:19
Yes traffic flows fine.
Cisco PIX 501 on the other end.
We'll try forcing and then disable CDP and see if that helps.
Tye
Trending Topics - Security & Network
