PIX, Nessus and the ip_id field in IP packets
When I scan the interface ip address of a PIX (version 6.2.2.111) with Nessus, I'm shown a Security Issue Warning refering to non-random ip id values in the ip_id field in IP packets. Some research indicates that this can be used for:
stealth os fingerprinting
anti-spoofing rule discovery
stealth scanning
Does the PIX use non-random ip id values?
Is this something that I should be concerned about?
If not what defense does the PIX have against these exploits.
Thanks in advance,
D.Sax
shannong Mon, 03/10/2003 - 17:21
  • Silver, 250 points or more
These aren't exploits. Exploits are used to compromise a host. These are information discovery techniques.
My mistake, you're right, this is an information discovery technique not a vulnerability. I still have some questions though:
Should I be concerned about this?
How does the PIX respond to this type of reconnaissance technique?
Can I or do I have to configure the PIX to defend against being used for or subject to this type of discovery?
