Warning message
Can't approve job when distributing image with SWIM
Mar 11th, 2003
I have a LMS 2.1 station with RME 3.4.
I retreived successfully images from cat6K with Software Management and
put them in the library.
I tried to restore an image from that library to a cat6K using distributing
image. For that, I scheduled a job in which I upgrade the switch with the
same image as it already has. I created an approval list with admin user and
when I tried to approve the job which is scheduled as admin user , the job will
never appear in the browser list of approval jobs. The list is always empty.
Is there something I miss in the process to distribute an image ?
beth-martin Mon, 03/17/2003 - 09:03
  • Bronze, 100 points or more
I would suggest you check the following for correct job approval:
1. Add the approver user account with Approver role. Select: CiscoWorks2000 Server > Setup > Security >Add Users.
2. Create Approver List. Select: Resource Manager Essentials > Administration > Job Approval > Create Approver List.
3. Enable the Software Management specific Job Approval option. Select: Resource Manager Essentials > Administration > Job Approval > Edit Preferences>SWIM
More questions answered here at:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_qanda_item09186a00800a6105.shtml
ppoiron Mon, 03/17/2003 - 09:14
Thanks for your informations.
I've already done that but with the login approver in the approver list I can't approve the job because the job doesn't appear in the list (the box is empty). So when the scheduled time is reached, the job is rejected.
Patrice
