Warning message
How to specify which modem to use for callback?
I am trying to setup the following on a router 2610 with two analog modems attached:
User dials in to router using modem1, service exec-callback, then the router should call back the user on modem2.
I can't figure out how to make the router use modem2 for the callback instead
of modem1, apart from the username based solution via
"username dialin callback-line 34". But I am looking for a generic solution that
applies to all users.
Can someone help?
Thank you
Dorothea
liviu.gheorghe Tue, 03/11/2003 - 08:39
  • Bronze, 100 points or more
You can configure the line for the first modem as "modem dialin" and the line for modem2 as "modem inout".
This way you can use both modems for dialin calls, but only modem2 can be used to call out.
I have done so (see below), but when I authenticate as user "callback"
the router tries to call back on line 33 (modem1). The same line that was
used for dialing in. Only when I authenticate as user "cb", who has
the "callback-line" specified it will use line 34 (modem2).
What I am looking for is a way to make the router always choose modem2
for calling back.
Here are the relevant parts of my running-config:
username callback callback-dialstring 3120 password 7 callback
username cb callback-dialstring 3120 callback-line 34 password 7 cb
interface Group-Async1
no ip address
no ip directed-broadcast
encapsulation ppp
dialer in-band
dialer rotary-group 1
async mode interactive
no peer default ip address
fair-queue 64 16 0
no cdp enable
group-range 33 33
interface Group-Async2
no ip address
encapsulation ppp
dialer in-band
fair-queue 64 16 0
no cdp enable
group-range 34 34
interface Dialer1
ip unnumbered Ethernet0/0
encapsulation ppp
dialer in-band
dialer enable-timeout 20
peer default ip address pool dialin
no cdp enable
ip local pool dialin 192.168.1.40
line 33
session-timeout 2
exec-timeout 2 0
script reset reset
script modem-off-hook offhook
script callback callback
login authentication dialin
modem Dialin
modem autoconfigure discovery
autocommand menu terminals
transport input all
transport output telnet
callback forced-wait 30
stopbits 1
speed 115200
flowcontrol hardware
line 34
session-timeout 2
exec-timeout 2 0
script reset reset
modem InOut
transport input all
stopbits 1
speed 115200
Cheers
Dorothea
liviu.gheorghe Tue, 03/11/2003 - 09:04
This is because you configured a dialer rotary group and the router tries to call out on the first available line in a rotary group.
Remove the dialer interface and the dialer rotary-group 1 from the 2 group-async interfaces, put the 2 async lines in one Group-async interface.
One of the lines will be configured with modem dialin and the other with modem inout.
I think this will do the trick.
I am afraid not. I have tried your suggestions, see below, but when
I login as "callback" the callback is still initiated on line 33. With "debug modem" and "debug callback" I get the following:
*Mar 5 18:38:58: TTY33: DSR came up
*Mar 5 18:38:58: tty33: Modem: IDLE->(unknown)
*Mar 5 18:38:58: TTY33: EXEC creation
*Mar 5 18:38:58: TTY33: set timer type 10, 30 seconds
*Mar 5 18:39:06: TTY33: set timer type 10, 30 seconds
*Mar 5 18:39:50: TTY33 Callback process initiated, user: callback dialstring 3120
*Mar 5 18:39:58: TTY33 Callback forced wait = 30 seconds
*Mar 5 18:39:59: TTY33: DSR was dropped
*Mar 5 18:39:59: TTY33: Quickly dropping DTR
*Mar 5 18:39:59: tty33: Modem: READY->HASPROC
*Mar 5 18:39:59: TTY33 Callback process fail - modemcheck status=80010601
*Mar 5 18:39:59: TTY33: Line reset by "Callback Process"
*Mar 5 18:39:59: TTY33: Modem: HASPROC->HANGUP
*Mar 5 18:39:59: TTY33: destroy timer type 0
*Mar 5 18:39:59: TTY33: destroy timer type 1
*Mar 5 18:39:59: TTY33: destroy timer type 3
*Mar 5 18:39:59: TTY33: destroy timer type 4
*Mar 5 18:39:59: TTY33: destroy timer type 2
*Mar 5 18:40:00: TTY33: dropping DTR, hanging up
*Mar 5 18:40:00: tty33: Modem: HANGUP->IDLE
*Mar 5 18:40:05: TTY33: restoring DTR
*Mar 5 18:40:06: TTY33: autoconfigure probe started
It seems to me it tries line 33 for callback and then notices that it
is configured for dialin only.
Here is the running-config:
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \c
chat-script reset "" "ATH1" OK
encapsulation ppp
fair-queue 64 16 0
no cdp enable
group-range 33 34
line 33
session-timeout 2
exec-timeout 2 0
script reset reset
modem Dialin
transport input all
stopbits 1
speed 115200
line 34
session-timeout 2
exec-timeout 2 0
script reset reset
modem InOut
transport input all
stopbits 1
speed 115200
liviu.gheorghe Thu, 03/13/2003 - 00:27
I did a test yesterday in my lab, and the result was the same like yours.
If your call is answered by line 1, the callback will be placed using the same line.
If the call is answered by line 2, then the callback will be placed using line 1, specified by username callback-line command.
I think this is either a bug or a feature.
As an workaround, if you want users calling into a line and the callback goung out the second line, give the users the phone number of the second line or swap lines.
