Warning message
c7200 and internal Flash
Mar 11th, 2003
We have a new cisco 7204. The IOS is located on the external pcmcia device (disk0:). The boot image is located on the internal boot flash. This seems to be default ...
For backup, I like to have a copy of the ios on internal flash. I have entered <show flash> an got the following message: Open device slot0 failed (Device not ready).
Is this a normal answer? How can I save a copy of the ios to internal flash?
Thanks in advance
Edgar
deilert Tue, 03/11/2003 - 10:35
  • Silver, 250 points or more
to see the contents of slot0:
do a dir slot0:
to see the contents of bootflash:
dir bootflash:
reinke Tue, 03/11/2003 - 10:46
With dir slot0: I get the following result:
%Error opening slot0:/ (Device not ready)
dir bootflash: ist working.
deilert Tue, 03/11/2003 - 10:51
I am sorry it is dir disk0:
try sh bootflash:
tepatel Tue, 03/11/2003 - 14:48
  • Cisco Employee,
Just a thought...
Just use "dir" on a # promt and see what files you have in which disk/slot
After that you can use "dir slot0: " and "dir slot1: " and you can use
"copy slot0: slot1: "
etc.....
reinke Tue, 03/11/2003 - 23:13
Me again ...
dir all-filesystem lists the following information:
- disk0:/
- system:/
- nvram:/
- bootflash:/
- lex:/ no files in directory
There is no slot0:/ (slot1:/) ...
With I get the following information:
Edgar
deilert Wed, 03/12/2003 - 04:48
what happens with a dir disk0:
reinke Wed, 03/12/2003 - 05:34
disk0: is working. But this is the content of the pc card ...
I only want to copy the content of this card onto internal flash (which seems not to be present).
Edgar
deilert Wed, 03/12/2003 - 07:45
do a pwd
This will show you what file system you are using. When you do a sh flash it will give you the contents of what ever device is your PWD. see below.
Router #cd slot0:
Router #pwd
slot0:/
Router #sh flash
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. image 2A309DCB A44830 21 10635184 Jun 24 2001 06:59:58 c7200-js-mz.121-8.bin
9915316 bytes available (10662988 bytes used)
Router#dir slot0:
Directory of slot0:/
1 -rw- 10635184 Jun 24 2001 06:59:58 c7200-js-mz.121-8.bin
20578304 bytes total (9915316 bytes free)
Router #cd bootflash:
Router#pwd
bootflash:/
Router#
Router#sh flash
1 .. image E87BFDE9 3121C8 21 2957640 Mar 25 2000 20:49:11 c7200-boot-mz.120-9.S
85940 bytes available (3321932 bytes used)
Router#dir bootflash:
Directory of bootflash:/
1 -rw- 2957640 Mar 25 2000 20:49:11 c7200-boot-mz.120-9.S
3407872 bytes total (85940 bytes free)
