It depends on where the ACL is going to be placed. If it is on the outside network interface, the router will see the NAT'ed IP in the packets, not your inside ip addresses. You would want your ACL to us the NAT'ed (internet IP's) in this case. If the ACL is on the inside network interface, the internal IP's would be used.
I hope that helps.
