call not end to end ISDN
we have a remote isdn site (804) that suddenly cannot connect to our receiving 3640. local telco and long distance providers have "tested" and ruled themselves out. other remote sites are fine. i can get them to connect with the 1010220 prefix. Does anyone know any buzz words that i can use to get the telco to own up to their problem..
Mar 12 12:52:15 EST: BR0 DDR: rotor dialout [priority]
Mar 12 12:52:15 EST: BR0 DDR: Dialing cause ip (s=10.232.3.3, d=10.76.0.99)
Mar 12 12:52:15 EST: BR0 DDR: Attempting to dial xxxxxxxxx
Mar 12 12:52:15 EST: ISDN BR0: TX -> SETUP pd = 8 callref = 0x17
Mar 12 12:52:15 EST: Bearer Capability i = 0x8890218F
Mar 12 12:52:15 EST: Channel ID i = 0x83
Mar 12 12:52:15 EST: Keypad Facility i = 'xxxxxxxxxxx'
Mar 12 12:52:15 EST: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0x97
Mar 12 12:52:15 EST: Channel ID i = 0x89
Mar 12 12:52:15 EST: Locking Shift to Codeset 5
Mar 12 12:52:15 EST: Codeset 5 IE 0x2A i = 70x80880B, 'xxxxxxxxx', 0x800109800114800114800114
Mar 12 12:52:17 EST: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0x97
Mar 12 12:52:17 EST: Cause i = 0x829F - Normal, unspecified
Mar 12 12:52:17 EST: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x17
Mar 12 12:52:17 EST: BRI0: wait for isdn carrier timeout, call id=0x8115
Mar 12 12:52:17 EST: DDR: Dialing failed, 2 packets unqueued and discarded
Mar 12 12:52:17 EST: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0x97
Mar 12 12:52:18 EST: BR0 DDR: rotor dialout [priority]
Mar 12 12:52:18 EST: BR0 DDR: Dialing cause ip (s=10.232.3.3, d=10.1.0.99)
Mar 12 12:52:18 EST: BR0 DDR: Attempting to dial xxxxxxxxxxx
Mar 12 12:52:18 EST: ISDN BR0: TX -> SETUP pd = 8 callref = 0x18
Mar 12 12:52:18 EST: Bearer Capability i = 0x8890218F
Mar 12 12:52:18 EST: Channel ID i = 0x83
Mar 12 12:52:18 EST: Keypad Facility i = 'xxxxxxxx'
Mar 12 12:52:18 EST: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0x98
Mar 12 12:52:18 EST: Channel ID i = 0x89
Mar 12 12:52:18 EST: Locking Shift to Codeset 5
Mar 12 12:52:18 EST: Codeset 5 IE 0x2A i = 0x80880B, 'xxxxxxxxxxx', 0x800109800114800114800114
Smithkline-college(config-if)#
Mar 12 12:52:22 EST: ISDN BR0: RX <- PROGRESS pd = 8 callref = 0x98
Mar 12 12:52:22 EST: Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Mar 12 12:52:23 EST: ISDN BR0: RX <- CONNECT pd = 8 callref = 0x98
Mar 12 12:52:23 EST: Progress Ind i = 0x8482 - Destination address is non-ISDN
Mar 12 12:52:23 EST: ISDN BR0: TX -> CONNECT_ACK pd = 8 callref = 0x18
Mar 12 12:52:23 EST: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Mar 12 12:52:23 EST: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
Mar 12 12:52:43 EST: BR0 DDR: has total 0 call(s), dial_out 0, dial_in 0
Mar 12 12:52:43 EST: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1
Mar 12 12:52:43 EST: BR0:1 DDR: disconnecting call
Mar 12 12:52:43 EST: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from xxxxxxxxxx , call lasted 20 seconds
xxxxxxxxxxxxxxx added second dial string xxxxxxxxxxxxxxxxxxxxxxxxxxx
Mar 12 12:56:47 EST: BR0 DDR: rotor dialout [priority]
Mar 12 12:56:47 EST: BR0 DDR: Dialing cause ip (s=10.6.95.232, d=10.76.0.101)
Mar 12 12:56:47 EST: BR0 DDR: Attempting to dial 5555555
Mar 12 12:56:47 EST: ISDN BR0: TX -> SETUP pd = 8 callref = 0x1B
Mar 12 12:56:47 EST: Bearer Capability i = 0x8890218F
Mar 12 12:56:47 EST: Channel ID i = 0x83
Mar 12 12:56:47 EST: Keypad Facility i = '5555555'
Mar 12 12:56:47 EST: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0x9B
Mar 12 12:56:47 EST: Channel ID i = 0x89
Mar 12 12:56:47 EST: Locking Shift to Codeset 5
Mar 12 12:56:47 EST: Codeset 5 IE 0x2A i = 0x80880B, '15555555', 0x800109800114800114800114.
Mar 12 12:56:48 EST: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0x9B
Mar 12 12:56:48 EST: Cause i = 0x829F - Normal, unspecified
Mar 12 12:56:48 EST: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x1B
Mar 12 12:56:48 EST: BRI0: wait for isdn carrier timeout, call id=0x8119
Mar 12 12:56:48 EST: BR0 DDR: Attempting to dial 10102205555555555
Mar 12 12:56:48 EST: ISDN BR0: TX -> SETUP pd = 8 callref = 0x1C
Mar 12 12:56:48 EST: Bearer Capability i = 0x8890
Mar 12 12:56:48 EST: Channel ID i = 0x83
Mar 12 12:56:48 EST: Keypad Facility i = '101022055555555555'
Mar 12 12:56:48 EST: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0x9B
Mar 12 12:56:49 EST: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0x9C
Mar 12 12:56:49 EST: Channel ID i = 0x89
Mar 12 12:56:49 EST: Locking Shift to Codeset 5
Mar 12 12:56:49 EST: Codeset 5 IE 0x2A i = 0x808812, '1010220555555555555555', 0x800102800114800114800114.!!!
makchitale Wed, 03/12/2003 - 10:43
  • Silver, 250 points or more
The very fact that the call goes thru using the 1010220 should be good enough for the telco....there seems to be an issue on the path the call takes without the 1010220 prefix....
Try locking the speed to 56k,
dialer map ip speed 56 name abc xxxx
OR
dialer string xxxx class 123
map-class dialer 123
dialer isdn speed 56
Thanks, Mak.
makchitale Wed, 03/12/2003 - 20:22
You probably have dialer Profiles configured (dialer pool xx)....On a non-DDR interface, for legacy ddr we need "dialer in-band" to add any dialer commands but for Dialer profiles we need "dialer pool" for adding any more dialer commands.
show run / sh ver.
Thanks, Mak.
