Warning message
Cisco Secure VPN client
Mar 12th, 2003
I'm using Cisco Secure VPN client 1.0a (also tried 1.1 version client) with Cisco 3660 IPSEC 3DES gateway/router [ IOS 12.0 (7)T ]
I'm getting this error message on router whenever client establishes a connection and it keeps repeating the same error message throughout the session (The speed is also very slow through DSL line).
Mar 11 16:43:36.900 PST: %SYS-2-BADBUFFER: Attempt to use contiguous buffer as scattered src, ptr= 61A32AA0, pool= 61990494
-Process= "<interrupt level>", ipl= 1
-Traceback= 60320350 6002C630 60335554
Mar 11 16:43:37.192 PST: %SYS-2-BADBUFFER: Attempt to use contiguous buffer as scattered src, ptr= 61A32AA0, pool= 61990494
Mar 11 16:43:37.484 PST: %SYS-2-BADBUFFER: Attempt to use contiguous buffer as scattered src, ptr= 61A32AA0, pool= 61990494
Can anybody suggest what might be the problem?
Thanks in advance.
awaheed Wed, 03/12/2003 - 11:01
  • Cisco Employee,
I think you might be hitting an internal bug CSCdz14405 which is fixed in 12.2.13T1 IOS version. Try updating the code and see how it goes.
Hope this helps,
Aamir
shekar.reddy Wed, 03/12/2003 - 11:21
Aamir,
I have seen this bug. Doesn't it say "This symptom is observed in 7200 series routers running 12.2.13T1"?
I'm using 3600 and I'm not running any MPLS service on it.
