Warning message
LAN firewall causes error sending email through Notes on VPN?
Mar 12th, 2003
I use cisco VPN dialer(3.5.2 Windows 2000 Professional) to connect back to my company VPN server through my clients' LAN's at different locations. At some client locations (mostly Healthcare organizations), I can not send email through Notes but IM/tcp/http/https/retrieving emails and all other functions are okay. If I insist to send email, it will fail and break the VPN connection. At most other clients, I don't have any issue with cisco VPN dialer. My question is, what client LAN firewall settings prevent me to send email through Notes? So I can talk to the clients to change the firewall policy to correct the issue. Is any way I can reconfigure my cisco client to avoid the problem?
Thank you!
afakhan Fri, 03/14/2003 - 22:07
  • Bronze, 100 points or more
You can try lowering down the MTU on the PC to around 1200B, by using the utility that comes with the vpn3000 client called setMTU.
Afaq
