Warning message
Problems with the outgoing calls with the CRA 3.0(2)
Mar 13th, 2003
has anyone installed the new version of the IVR 3.0(2), and deploy the functionallity of the outgoin calls, becuase i have some problems,
I start the application of the outgoing calls, and it starts ok, it begun to dial the customer phone numbers, but suddenly it stops,
Could be at the first call or could done 20 calls,
Does anyone has the same problem
adignan Sun, 03/16/2003 - 20:18
  • Blue, 1500 points or more
Make sure the CTI ports you are using have the correct calling search space to make outbound calls?
amontes Mon, 03/17/2003 - 06:55
All the CTI ports have the correct calling search space, but i have no problem to do the outbound calls. it start but suddenly it stops to make it.
Sometimes only did 10 calls, sometimes only 1 call, and stop, thats my problem why it stops makeing calls?
r.siddappa Wed, 04/02/2003 - 21:33
May be it is somethign to do with your Jtapi or CTI server.
Look at the Jtapi logs.
