Warning message
How to verify and change the timer of IS-IS?
Mar 13th, 2003
Hi All,
I had tried to find document but I can not find the answer. Does any body know the IS-IS timer in Cisco router and Can I change it? So far I just can find command to change the IS-IS interface metric.
Best Regards
Teru Lei
Overall Rating: 4 (1 ratings)
bbranch Fri, 03/14/2003 - 00:44
  • Silver, 250 points or more
The timers are:
Hello - 10 seconds - changed via isis hello-interval command
Hold Time - 30 seconds (3 x Hello Interval) - changed via isis hello-multiplier command
LSP Retransmission timer - 5 secinds - changed via isis retransmisit-interval command
CSNP timer - 10 seconds - changed via isis csnp-inteval command
The IS-IS Max Age is 20 minutes
LSP refresh interval is 15 minutes
Zero Age timer is 60 seconds
teru-lei Fri, 03/14/2003 - 00:55
Thank you for your reply. May I ask you one more question? Do the timer change in different type interface? or the timer do not change? If the timer do not change, why a point-to-point interface can not form neighbor with a multipoint interface? Thank You!
Best Regards
Teru Lei
bbranch Fri, 03/14/2003 - 01:46
Two different types of Hello are used in ISIS, Point to Point Hello's and LAN (or Broadcast) Hello's (and the LAN Hello's are subdivided into two more types- Level-1 and Level-2).
Neighbors are requires to use the same type of Hello's. A Multipoint interface will use a LAN (or Broadcast) Hello and a Point to Point interface will use a Point to Point Hello, in this case no neighbor relashonship will be formed as there is a Hello type mismatch.
