What is the difference between unrestricted and restricted.
Mar 14th, 2003
I am considering to buy a PIX firewall but the vendor told me that what type of software I want unrestricted or restricted. What differs there are between both.
Overall Rating: 2.7 (3 ratings)
mostiguy@netnum... Fri, 03/14/2003 - 10:46
It depends on the model.
A 515 R = no failover, and you can only use 3 interfaces
515 UR = can use failover (if you buy a pix 515 with the failover license kit), and can use up to 6 interfaces.
525 and 535 have similar limitations.
msvarga Fri, 03/14/2003 - 13:20
My question is more related with the restrictive of using unrestricted and restrictive license in the failover.
Do you know what is the difference?
haleemk Mon, 03/17/2003 - 04:55
Best is to Contact Cisco vendor/partner to know the difference.
Thanx
mostiguy@netnum... Mon, 03/17/2003 - 07:10
If you want to buy a pair for a failover setup, you need to buy identical units, but with different licenses - one needs to have the unrestricted license, and the failover unit needs to have the failover license.
Cisco has different SKU for each package - for example, there is a part number for pix515UR, another for pix515R, and a third for 515FW
