Warning message
shannong Sat, 03/15/2003 - 08:23
  • Silver, 250 points or more
Yes. Remember that it is only helpful if you have an ACL with more than 19 entries. Also, note that the Pix will recomplie the ACL everytime you make a change. If the ACL is long and the traffic levels are high, you might see CPU resource issues that can cause traffic to be dropped or significantly delayed when a change is amde.
josephsilvin Sun, 03/16/2003 - 21:32
I understand that the TurboACL is recommended for PIX 525 and 535 models. Mine is a PIX 515. Also I read that TurboACL takes around 2.1MB of memory and also takes around 1MB for every 2000 ACL elements.
I would like to know whether there is any change in the memory requirement if the facility is applied to a particular access-list only rather than appling across all access-lists.
i.e access-list acl_ID compiled and access-list compiled
Thanks.
