Warning message
gfullage Tue, 03/18/2003 - 15:16
  • Cisco Employee,
how to what?
If you mean you only have one IP address, then for outbound traffic do:
> nat (inside) 1 x.x.x.x
> global (outside) 1 interface
If you have any internal servers that require connections from the outside, then you'll have to port-map them with a static thus (example using port 25):
> static (inside,outside) tcp interface 25 y.y.y.y 25 netmask 255.255.255.255
where y.y.y.y is your internal SMTP server address.
nsteup Fri, 03/21/2003 - 02:07
Hi Glenn,
there is one problem in configuring that. You need to define an access-rule outside incoming like following:
access-list outside_in permit tcp any host "outside ip" eq 25
now if your pix receives an ip address via pppoe or dhcp from your provider, how will you change your "outside ip" dynamically?
So your config is correct and works fine if you have one ip address AND if it is static defined by your provider.
Regards Norbert
