WGB Config
Mar 19th, 2003
Does anyone know a solution for the following problem:
i have dumped the config from a wgb. i want to ftp the config to a new wgb and also want to have the eap password in the config.
is there a syntax to add the password to the config like:
@346 eap ! send , configuration security mode eap
@355 "testuser" ! local, configuration security username "testuser"
@366 "EAP PASSWORD"
thanks for help
bernhard
BERNHARD FIEGLM... Wed, 03/26/2003 - 08:42
thx for reply, but i know how to configure the password over the webpage. the reason why i want it is bc i have much wgb to role out i just want to ftp (or bootp) the config WITH THE EAP PASSWORD bc we are using leap for authentication for the wgb. when i dump the config from a wgb i dont have the password in it (also in aps) but i want to enter the password manually. so i need the string in the config.
bernhard
Trending Topics - Security & Network
