Warning message
dialing configuration
makchitale Wed, 03/19/2003 - 19:31
  • Silver, 250 points or more
When the central site has 6 numbers in a hunt group means the remote routers will have to dial the same number...suppose the first line is busy with a modem call then the telephone switch should route the call to the next modem line automatically....there is no special configurations needed on the central side router for this to happen.
For the central site the config should be as below:
http://www.cisco.com/warp/public/793/access_dial/pppdialup.html
For the remote side to callout, use below config...instead of aux port in the sample config, you can configure the appropriate port / line that the modem is connected on.
http://www.cisco.com/warp/public/471/mod-aux-dialout.html
Thanks, Mak.
makchitale Wed, 03/19/2003 - 20:38
If you cannot use dynamic routing protocols then will need to use static routes on all the routers...depending on how your overall network toplogy is, will need to add lots of static route commands.
Just curious, did you mean security reasons for not using dynamic routing protocols?
http://www.cisco.com/warp/public/105/default.html
Thanks, Mak.
using static route,I must special the next-hop address,but when dial in ,the center site will dynamic assign a address to remonte clients,next time ,the address may be different.so I cannot configure it.maybe I can use default route,but remote clients not only connet to center site,but connet to other sites.
Can I still use default route?
If using dynamic routing protocols,the updating route will announce internal networks.so I think it is not security.
Thanks,Ricky
makchitale Thu, 03/20/2003 - 20:42
Using dialer profiles can create dialer interfaces on the central site for each remote site dialing in & assign static ip addresses to the remote dialin.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt5/dcdiprof.htm
The static routes can also be pointed to the routers interface (outgoing), eg,
ip route x.x.x.x y.y.y.y dialer1
If you have a big network with the requirement to connect between various sites then using a dynamic routing protocol with be the best way.
Thanks, Mak.
Mak,sorry for reply late
the following is the configuration of routers.
........................................remote client...............................................................chat-script dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45 CONNECT \c
modemcap entry MY_USR_MODEM:MSC=&F1S0=1
interface loopback0
ip address 148.254.254.5 255.255.0.0
interface FastEthernet0/0
ip address 148.1.201.11 255.255.0.0
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface Serial0/1
description to 'renhang'
bandwidth 64
ip nat outside
backup delay 0 1
backup interface Serial3/4
ip address 9.148.48.114 255.255.255.252
encapsulation frame-relay IETF
keepalive 5
clockrate 2000000
frame-relay interface-dlci 451
frame-relay lmi-type ansi
interface Serial3/4
physical-layer async
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 20
async default routing
ppp authentication chap callin
interface Dialer10
ip unnumbered loopback0
ip nat outside
encapsulation ppp
dialer pool 20
dialer remote-name ci3662r
dialer string 66790871
dialer-group 1
ip nat pool natpool 9.148.45.1 9.148.45.110 netmask 255.255.255.0
ip nat inside source list 111 pool natpool overload
ip route 9.148.47.0 255.255.255.0 9.148.48.113
ip route 9.148.47.0 255.255.255.0 Dialer10 200
access-list 111 permit ip 148.0.0.0 0.255.255.255 9.148.47.0 0.0.0.255
dialer-list 1 protocol ip permit
router igrp 1031
network 9.0.0.0
network 148.254.0.0
network 100.0.0.0
line 101
exec-timeout 0 0
script dialer dialout
modem InOut
modem autoconfigure type MY_USR_MODEM
transport input all
stopbits 1
flowcontrol hardware
..........................................................center router......................................................
interface Loopback0
ip address 100.199.192.1 255.255.255.240
ip address 9.148.47.254 255.255.255.0
ip broadcast-address 9.148.47.255
duplex auto
speed auto
no cdp enable
interface Serial1/3.6 point-to-point
description nongfa
ip address 9.148.48.113 255.255.255.252
ip broadcast-address 9.148.48.115
frame-relay interface-dlci 470
interface Serial2/0
ip unnumbered FastEthernet0/0
encapsulation ppp
async dynamic routing
async mode dedicated
peer default ip address 9.148.47.195
fair-queue 64 16 0
router igrp 1031
network 9.0.0.0
network 202.100.99.0
network 148.254.0.0
ip classless
ip route 148.0.0.0 255.0.0.0 9.148.48.114
line 65
modem InOut
modem autoconfigure discovery
transport input all
autoselect ppp
stopbits 1
speed 115200
.....................................................................end..................................................
AS primary line down,remote router can diall in and connect to center site.
but "ping 9.148.47.254",time out.
if I remove "ip inside nat,ip outside nat" from remote router,"ping 9.148.47.254",reply from.....
Can interface of dailer support NAT?If yes,how to configure it?
thanks Ricky
