Warning message
SPAN on 2950's
Mar 21st, 2003
I'm wanting to monitor incoming and outgoing traffic and am having some trouble.
Both the port needing to be monitored port(source) and the port w/ the sniffer on it(destination) are on the same vlan on a 2950-48. After reading up on SPAN and having done something similar on a 1900 and 2924 switch I configured SPAN with the following commands:
monitor session 1 source interface FastEthernet0/4
monitor session 1 destination interface FastEthernet0/7
Afterwards the sniffer on fa0/7 was down. Only after I read the below url
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a0080150bca.html#1036749
Did I find that destination SPAN ports can't forward normal traffic - so basically if you have a sniffer/traffic analizer on that port you loose the ability to communication w/ that device remotely.
Is it just me or is that totally unacceptable.........
On the trusty 2924 you'd just configure a monitor port like so..
conf t
inter fa0/7
port monitor FastEthernet0/4
then all traffic going in or out of fa0/4 would be forwarded to fa0/7 AND you'd be able to communicate with the device on fa0/7.
What happened that this isn't allowed anymore??? I need remote access to this traffic analizer while its doing its job. However I can't do that w/ my 2950-48 but I could do the job with the older 2924?
What gives??? This seems like a step backwards to me...
t.baranski Sat, 03/22/2003 - 14:46
  • Bronze, 100 points or more
While it's always good to have options, I'll note that it's generally best practice to put a sniffing interface in "stealth mode" (i.e., no IP address) and use a second interface on the sniffing device as the admin interface (with an IP address, connected to another port on the same switch). This prevents your TELNET/SSH/VNC/etc connection from being slowed down (or maybe stopped altogether) when the amount of traffic flowing through the SPAN port is high
