Warning message
to tepatel
Mar 23rd, 2003
I want to connect to them by frame-relay or ddn,dial-in line as backup line .Bei jing as central. Shang Hai and Tian jing as branch office.If I use frame-relay ,I use point-to-multipoint to connect them .I want to let them to go to internet by Bei Jing.I don't know how to select csu/dsu equipment .please help me !I will thanks a lot!
vmiller Sun, 03/23/2003 - 18:09
  • Gold, 750 points or more
have a seperate router/firewall for access to the internet.
shanghi--------->beijing (headend router) -----fasthethernet---firewall---internet.
If you have a local Cisco office they can help with the DSU/CSU selection that
could be built into the router. this works will with frame relay.
zcyzaw Sun, 03/23/2003 - 22:10
I have set 2610 series router in beijing.I have set 1721 series router in Shang hai and Tian jing.I select DTU2602 as csu/dsu ,because I need 128k bandwidth,Do you think it is able to do ?please give me my answer.
