Ciscoworks2000 - IDU's
Answered Question
Mar 24th, 2003
We have procured the cw2K LMS 2.1 s/w upgrade bundle. I assume I will also need the latest IDU's for Ciscoview, DFM, RME and Campus Manager.
Can I just download and install the latest from CCO and be assured that the previous bug fixes ( eg CSCdy27717, CSCdx74889 )etc are included or do I need to download all of the download files to include historic bug fixes, patches and updates???
Correct Answer by rmushtaq about 14 years 5 months ago
All IDUs are cumulative and contains the device support and fixes from the previous IDU versions. But for a specific bug fix, it's always a good idea to go through the Readme file of the IDU which contains the list of bugs fixed to make sure that it covers the bug that you're looking for.
Overall Rating: 5 (2 ratings)
milan.kulik Mon, 03/24/2003 - 08:08
  • Red, 2250 points or more
I was told by a Cisco represenatative that IDUs are cummulative, e.i. I need only the latest one.
If you want be 100% sure read the IDU readme file (it contains a list of all bugs fixed).
The RME.3.4 IDU 3.0 readme file says:
"Earlier patches containing fixes these bugs have been rolled into IDU. When you
install IDU 3.0 it does not affect prior installation of Essentials 3.4 patches
including IDU 1.0 and 2.0."
Don't forget you need a separate IDU for RME, CM, DFM, etc.
Milan
rmushtaq Mon, 03/24/2003 - 10:30
  • Blue, 1500 points or more
Correct Answer
