Warning message
CSV file format for deleting devices
Mar 24th, 2003
I have RME 3.4 and use the CSV file format for importing devices into CW2K. Due to a renaming scheme going on thru the network I will need to delete several devices per day from our CW2K servers.
What is the CSV format for the Delete from File found in Administration>Delete from FIle?
I have tried the same as the import from file and normally use the crimport command in unix.. but this does not work when attempting a delete
Anyone know the correct CSV format?????
rmushtaq Mon, 03/24/2003 - 17:21
  • Blue, 1500 points or more
Delete from File uses the exact same .csv file that Import From File use.
Ensure that you export device information to a CSV file. The CSV file with the inventory data is saved at the following location: NMSROOT/files/inventory (in case of Windows) and /opt/CSCOpx/files/inventory (in case of UNIX). Edit the CSV file, so that it contains the devices you want to delete from your network.
Either use the GUI or the CLI script:
NMSROOT/bin/perl deleteDevice.pl -[option] filename -u username - p password
Where option:
s Suspend the devices
d Delete the devices
Where:
filename Valid CSV filename that contains the list of devices to be deleted. Only CSV file is supported.
username CiscoWorks server username.
password CiscoWorks server password.
