Warning message
vpnclient 3.7.3 and redhat 8.0
Mar 25th, 2003
has anybody been able to install this? i have not. is there like a good explanation on how to achieve this?
i don't have that much experience with linux, but i'm sure there is a problem with the install script.
can anybody help?
nick.garigliano... Tue, 03/25/2003 - 10:19
I have it running under Gentoo. I haven't tried using dig certificates yet but it does work. You have to manually define a profile file in /etc/CiscoSystemsVPNClient/Profiles and then make sure that you've run vpnclient_init that should me located in your /etc/rc/init.d directory (I think that is it for RH. For Gentoo it is different). After that you can do a vpnclient connect xxxx.pcf.
