Playing back recorded conversation recorded with Agent Desktop on CRS
Running CRS 3.0.2. Am setting up call recording/monitoring and am having trouble locating the appropriate steps. How does one play back recorded calls and setup call monitoring. I have a dual nic CRS that has the second NIC setup as the "sniffer" placed in VLAN 600. I have 2 test sets in VLAN600. Monitoring on the switch is set to monitor destination (to "sniffer port) from source VLAN 600. I am appearing to record the calls.
I can open up the Supervisor Log Viewer, however, playing the logs yields nothing.
Advice or a link would be very helpful.
Cheers
Update:
I've located the audio files folder (per Supervisor.pdf.), but all files are only 1k in size and have not stream to them (i.e. - 0 seconds long). Here is my switchport config for the 2 phones I'm testing between:
interface FastEthernet3/47
description IP PhonePC (monitored)
switchport access vlan 201
switchport trunk native vlan 201
switchport mode trunk
switchport voice vlan 600
duplex full
speed 100
no snmp trap link-status
spanning-tree portfast
interface FastEthernet3/48
description IP Phone/PC (monitored)
duplex full
speed 100
here's the monitoring:
monitor session 1 source vlan 600
monitor session 1 destination interface Fa2/41
here's the CRS "sniffer" port
interface FastEthernet2/41
description CRS Monitoring Port
switchport access vlan 600
duplex full
speed 100
Cheers
