Warning message
Cryptographic software updates for CallManager 3.2(2c)
Mar 26th, 2003
  • Blue, 1500 points or more
Hello -
Does the win-OS-Upgrade.2000-2-3spI.exe on the cryptographic site for CCM 3.2(2c) apply Windows 2000 SP3? I could not tell specifically from reading the document. Checking here for compatibility information on Windows 2000 SP3 before applying the WEBDAV MS003-007 security update (which runs on either SP2 or SP3). Or, should we wait until CCM 3.3 to bring in the Win2K SP3 version?
Thanks in advance. Ginger
dgoodwin Thu, 03/27/2003 - 06:45
  • Cisco Employee,
Hi Ginger,
The proper procedure to apply the MS03-007 security update on a CallManager server is to first run c:\sti\stiver.exe to check the current OS level.
If the WinOS level is already 2000.2.3 then skip to step 2:
1) Install win-OS-Upgrade.2000-2-3.exe
2) Install win-OS-Upgrade.2000-2-3spI.exe
3) Install win-MS03-007.EXE
Note: win-OS-Upgrade.2000-2-3 is what applies Windows 2000 Service Pack 3, and it is supported on all versions of Cisco CallManager 3.x servers.
Ginger Dillon Thu, 03/27/2003 - 15:56
Hi Dave -
Thanks so much!
Sincerely, Ginger
