Warning message
Deny Inbound (No xlate) src outside dst outside
Mar 27th, 2003
All,
My problem is the routing on the same interface (outside) in the PIX Firewall.
The solution that i've though is the command static (outside, outside) but unfortunately it didn't work,i've experienced the same on the inside interface with the command static (inside, inside) and it worked.
Does anyone a suggestion about?
Thanks in advance
tvanginneken Thu, 03/27/2003 - 08:14
  • Silver, 250 points or more
The PIX does not route packets that arrive on a certain interface and go out again on that same interface. Only packets that go 'through' the PIX are routed (eg from inside to dmz, for inside to outside, for dmz to outside,....)
Kind Regards,
Tom
