reducing wan cost over satlinks
Mar 27th, 2003
Hi ,
i have a sattlite point to point conecction between my offices
one in america and another in asia
i wanted to know if there is any kind of compression technology
to implement on both sides of the link
so we can reduce the cost of our link
thanks,
ji.xie Thu, 03/27/2003 - 21:38
you can run compress on your interface.
rais Fri, 03/28/2003 - 06:31
  • Silver, 250 points or more
You should analyze your TCP data, if any, and then try to tweak different TCP parameters.
If your data is already compressed, like jpg images, you wont get any benefit from compression.
Thanks.
farshid_sh Fri, 03/28/2003 - 23:56
thank you for your suggestions and comments
the most important thing that i do care about is latency
unfortunatly software based compressions put high utilization on cpu
and thus increasing the latency
that's why i need some kind of hardware based compression
for my link
all comments are welcomed
