Warning message
e1 controller - permanently reset
Mar 27th, 2003
I have an e1 controller connecting via standard megastream (RJ-45 / G.703 presentation) and basically trying to create a standard point to point link.
However as soon as the controller is plugged into the line, the interface appears as reset?
The router (2610-XM) passes its local diagnostics i/e line up/protocol up but then when the test finishes drops straight back to 'reset'
I am also seeing some BPV errors at the remote end however this is not Cisco equipment (unfortunately)
Any ideas?
tepatel Thu, 03/27/2003 - 20:40
  • Cisco Employee,
For point to point link, make sure that the other side E1 is also configured accordingly. Now we need to see the running config from the cisco router.
jmpowell Fri, 03/28/2003 - 02:36
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname router1
enable secret 5
enable password
ip subnet-zero
controller E1 0/0
framing NO-CRC4
clock source free-running
channel-group 1 timeslots 1-31
interface Loopback0
ip address 192.168.254.1 255.255.255.255
interface FastEthernet0/0
ip address 10.10.100.254 255.255.255.0
no ip mroute-cache
speed auto
half-duplex
interface Serial0/0:1
description Interface linked to E1 controller Channel Group 1
ip address 96.12.1.2 255.255.255.252
encapsulation frame-relay IETF
logging event subif-link-status
logging event dlci-status-change
frame-relay map ip 96.12.1.1 17 broadcast
frame-relay interface-dlci 17
frame-relay lmi-type ansi
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0:1
ip route 10.100.0.0 255.255.0.0 96.12.1.1
ip http server
line con 0
line aux 0
end
tepatel Sun, 03/30/2003 - 16:31
  • Cisco Employee,
Are you sure about the framming is no-crc4? Also the clock source should be "line". So talk to service provider about framming and clock source.
Here are some links which will help you for E1 troubleshooting.
http://www.cisco.com/warp/public/116/E1_error.html
On the bottom of that page, there are some useful links for E1 line toubleshooting.
