Warning message
Difference between configuring the "ip access-group" on interface Dialer an
Mar 28th, 2003
  • Bronze, 100 points or more
In the following configuration,
version 12.2
hostname NCR-shibuya
logging buffered 400000 informational
enable password xxx
username xxx password 0 xxx
ip subnet-zero
no ip source-route
no ip domain lookup
isdn switch-type ntt
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key xxx address x.x.x.x
crypto ipsec transform-set isdn esp-des esp-sha-hmac
crypto map enc 10 ipsec-isakmp
set peer x.x.x.x
set transform-set isdn
match address 150
interface BRI0
no ip address
ip access-group 110 in
no ip proxy-arp
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool-member 1
no cdp enable
interface FastEthernet0
ip address 192.168.0.30 255.255.255.224
speed auto
no cdp enable
interface Dialer0
ip address negotiated
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer string 1492
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 0 xxx
ppp pap sent-username [email protected] password 0 xxx
crypto map enc
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 110 permit ip host x.x.x.x host y.y.y.y
access-list 150 permit ip host y.y.y.y host x.x.x.x
access-list 150 permit ip 192.168.0.0 0.0.0.31 10.116.3.0 0.0.0.255
access-list 150 permit ip 192.168.0.0 0.0.0.31 10.116.2.0 0.0.0.255
access-list 150 permit ip 192.168.0.0 0.0.0.31 10.116.4.192 0.0.0.63
dialer-list 1 protocol ip permit
no cdp run
snmp-server community public RO
snmp-server enable traps tty
snmp-server host 10.116.2.216 public
line con 0
stopbits 1
line aux 0
line vty 0 4
login local
end
We configure the "access-list 110" to permit the ESP and ISAKMP packets
between IPSec end points and then apply this "access-list 110" to interface
Dialer0 with "ip access-group 110 in" to pass through the interface Dialer0.
"access-list 110 permit ip host x.x.x.x host y.y.y.y" means,
x.x.x.x : IP address of remote IPSec router
(remote IPSec tunnel end point IP address)
y.y.y.y : IP address of own IPSec tunnel end point IP address
When we apply "access-list 110" to interface Dialer0 with "ip access-group
110 in", this "access-list 110" does not work. That is, we can not IPSec
communication between two IPSec routers.
However, we remove "ip access-group 110 in" from interface Dialer0 and
configure "ip access-group 110 in" on interface BRI0 instead, this
"access-list 110" work fine.
That is, we can do IPSec communication well.
Above configuration is for this case.
My question is:
In this configuration (using interface Dialer0), we must configure the
"ip access-group" on real interface (int BRI0) not logical interface (int Dialer0),
although "crypto map" is configured on logical interface (int Dialer0) not real
interface (int BRI0) ?
If so, this is the normal behavior or restriction or bug ?
Any comments would be appreciated.
afakhan Fri, 03/28/2003 - 13:08
interface Dialer0 is where you access-list should be applied to, BRI interface doesn't have any ip address associated with it.
If you can still get your tunnel up, but data doesn't pass when you the above ACL on the D0 interface, then make sure that you permit the local LANs also in the ACL#110, because IPSec packets are subject to double ACL checking (before decryption/after decryption) on the receving crypto router.
Thx
Afaq
