Warning message
VLAN's and DHCP
Answered Question
Mar 28th, 2003
I'm unable to get dhcp addresses from my win2k server to pc's on different vlans. We are using cisco 3550-SMI switches. The dhcp server is on one vlan, and if I place the pc in the same vlan it is able to receive an ip address. All the other vlans are unable to get a address. I have the scopes defined on the server, and in the options I've defined the router's ip address as that vlan's ip address. Below is a config. Any ideas?
ip routing
ip dhcp-server 10.14.0.5
interface FastEthernet0/1
switchport access vlan 16
switchport mode access
no ip address
interface Vlan1
ip address 10.14.0.2 255.255.255.0
interface Vlan16
ip address 10.16.0.1 255.255.255.0
router rip
network 10.0.0.0
neighbor 10.14.0.1
ip default-gateway 10.14.0.2
ip classless
ip route 10.0.0.0 255.0.0.0 10.14.0.1
Correct Answer by donewald about 14 years 4 months ago
You need to configure a ip-helper address on your vlan interfaces to tell this device to pass the DHCP discovery message on to your DHCP server.
Like this
interface Vlan1
ip-helper
You'll need to do this for each VLAN interface that is not on the same VLAn as your DHCP server.
Hope this helps you,
Don
Overall Rating: 5 (1 ratings)
Correct Answer
donewald Fri, 03/28/2003 - 08:08
  • Silver, 250 points or more
Like this
interface Vlan1
ip-helper
Don
