ISDN Q931 Cause Code 0x8AFF
Mar 28th, 2003
Looking for suggestions on troubleshooting cause code 0x8AFF disconnect from a network beyond the internetworking point. Specific NPA NXX cannot be reached from IP Tel gateway PRI DMS100.
makchitale Fri, 03/28/2003 - 10:44
  • Silver, 250 points or more
Was this working before? Can you please send the complete the output of isdn q931.
Thanks, Mak.
dpyee Fri, 03/28/2003 - 12:02
New CIPT installation and DID range. The calling NPA NXX is unreachable only from CIPT phones with new DID range. I'm wondering if the distant cellular service provider does not recognize the new DID as valid.
Mar 28 16:34:09.712: ISDN Se3/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2147
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x00, 0x81, '6046764910'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '814168218384'
Mar 28 16:34:09.796: ISDN Se3/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xA14
7
Mar 28 16:34:10.940: ISDN Se3/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0xA147
Cause i = 0x8AFF - Interworking error; unspecified
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band inf
o
Mar 28 16:34:10.944: ISDN Se3/0:23 Q931: TX -> STATUS pd = 8 callref = 0x2147
Cause i = 0x80E4 - Invalid information element contents
Call State i = 0x04
tepatel Fri, 03/28/2003 - 16:56
  • Cisco Employee,
That is possible. But i don't see that call is getting disconnected yet (sa its not included in the debug here). 0x8AFF is basically a From a network beyond the internetworking point giving reason as unknown for disconnect.
You will find isdn disconnect cause codes with explanation at following url
http://www.cisco.com/warp/public/129/isdn_disc_code.html
