Warning message
Call Transfer doesn’t work
Answered Question
Mar 30th, 2003
Hi to all
I have Unity 3.1 Build 3.1(5) and CCM 3.1(3a). On gateway is codec g711ulaw set. I can send voicemail, communicate over phone with Unity, but Call Transfer does not work. Any of options doesn’t work.
Any suggestions?
With regards
Dubravko
Correct Answer by oliviers about 14 years 4 months ago
It sounds like you want to set the forwarding on that phone. There's a difference between transferring and forwarding. The transfer settings in Unity are for when a caller is in voice mail (that, is Unity has answered an incoming call), now if a caller dials the DTMF ID of the subscriber, what does Unity do: transfer the caller to that phone or not. That's the call transfer settings in Unity.
For calling the phone directly, you'll want to set up forwarding on that phone and that's controlled by CallManager. Does that make sense?
Overall Rating: 5 (1 ratings)
oliviers Mon, 03/31/2003 - 09:00
  • Cisco Employee,
Can you give an example call flow including the call transfer options? Can you provide what you want to happen and what is instead happening?
dubravko.vukmir... Mon, 03/31/2003 - 23:46
Hi thanks for replying.
1 Example: Subcriber - Call Transfer - Transfer incoming calls to subscriber's phone? - No (send directly to subscriber's greeting)
When I call from internal number or PSTN 7940 only rings.
2 Example:
Yes, ring subscriber's extension:
Transfer type:
Supervise transfer
Rings to wait for 2
That is with all options in call transfer
My Voice number is 272. When I forward calls to 272 I hear greetings and I can leave message which come to my Inbox.
Thanks for help
Correct Answer
oliviers Tue, 04/01/2003 - 08:33
  • Cisco Employee,
