Warning message
Connectivity Problem with NM 4T & WIC 2T
Mar 31st, 2003
I have Cisco Router 2610 with WIC 2T, & Cisco Router 3640 with NM 4T.
Connected back to back.
What is the configuration should i apply for this routers to make a connection.
Also i want to know compatilibity of NM 4T with 2610 Router.
Mudassir.
a.manosca Mon, 03/31/2003 - 00:56
  • Bronze, 100 points or more
There should be no special configuration required when connecting the routers back-to-back. We have even tried connecting a 1700 with the 3640's NM-4T with no problem. Just set the IP addresses on both routers and a clocking on the router with the DCE cable. NM-4T is not supported on 2600 series.
mmali Mon, 03/31/2003 - 01:13
I tried clocking 115200. but it is not excepting it.
it is taking 240.
interface shows down down.
