Command "switchport port-security violation shutdown"
Answered Question
Mar 31st, 2003
Hi all,
When use port-security in the switch, we use switchport port-security mac-address x.x.x to config the port, but what's the difference with the "switchport port-security violation shutdown" command? Thank You!
Best Regards
Teru Lei
Correct Answer by ndoshi about 13 years 10 months ago
shutdown—When a port security violation occurs, the interface is error-disabled and the port LED is off. When a secure port is in the error-disabled state, you can bring it out of this state by entering the errdisable recovery cause psecure-violation global configuration command, or you can manually re-enable it by entering the shutdown and no shutdown interface configuration commands. This is the default mode.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a0080150bcd.html
Nilesh
Overall Rating: 5 (1 ratings)
Correct Answer
ndoshi Mon, 03/31/2003 - 19:06
Nilesh
