Change pin password length?
Apr 2nd, 2003
Hi there..
Is it possible to change the pin password length for users in CCM?
5 minimum is default.
I would like to change this to 4.
4 digits is more easy to remember than 5.
Best Regards
/Andreas Ekstrom
Overall Rating: 5 (1 ratings)
jbayuka Tue, 04/08/2003 - 07:22
  • Bronze, 100 points or more
I think a 4 digit PIN would be a good option for me too. I researched a bit and there is no way to change this to 4 as far as I can find.
Phillip Ratliff Tue, 04/08/2003 - 10:50
  • Cisco Employee,
-Go into the DCD Admin.
-Directory->cisco.com->CCN->systemProfile
-right click on systemProfile and go to properties (right hand window)
-go to CCM Configuration tab, the field is there. Click Modify and go to town.
