CW2K not archiving all configs
Apr 3rd, 2003
I am getting the following when I go into Config management on RME. I try to pull up a config on a device.
PGM_NM=Configuration Archive:6219:TYPE-unassigned message type::Error creating the configlets for /var/adm/CSCOpx/archive/config/523/20030228000607running.cfg file Cat
Probable Cause
PGM_NM=Configuration Archive:6220;Type=unassigned message type::The file is not a valid file.
Recommended Action
Specify a fully qualified file name.
thomas.chen Wed, 04/09/2003 - 11:17
  • Silver, 250 points or more
Be sure that you are stopping and starting the CiscoWorks daemons after making the changes to your archive directory
(/etc/init.d/dmgtd stop,followed by /etc/init.d/dmgtd start)
If you have done this, you can turn on debugging to find out what's going on when you're doing the Config Archive
To do so,edit the following file
/opt/CSCOpx/www/classpath/com/cisco/nm/config/archive/config.properties
and set DEBUG_LEVEL to 5.
Then stop and start the Ciscoworks daemons (as per above) and try a report, you will want to look through the following logs:
/var/adm/CSCOpx/log/daemons.log
/opt/CSCOpx/objects/jrun/jsm-cw2000/logs/{stdout.log,stderror.log
