Warning message
PIX and ADSL router.
Answered Question
Apr 4th, 2003
I have, in one site, a PIX 515 connected to a C827H (an ADSL router “doing” PPPoE). This router gives access to the Net. In another site I have another PIX (a 506) and another C827H router that gave access to Net. Both sites have access to net without problems. But when I what to establish a VPN tunnel (with Ipsec) between this two sites, through the Net, I can’t establish the connection. The ADSL router has their public IP negotiated with the ISP. In my lab I simulate this two connections putting two PIXs (a 520 and a 506) back-to-back with a crossover cable. I used the same configuration. The thing worked. But in my two sites that is not working. Why?
Correct Answer by xiaoj about 14 years 4 months ago
I see, in that case. I suggest you change the ACL name defined in crypto map, try not to use the same ACL that you used for nat0, it causes problem sometimes.
Try that and see if it works for you.
-Jimmy
Overall Rating: 3 (1 ratings)
xiaoj Fri, 04/04/2003 - 11:04
Can you post your configuration?
rcapao Tue, 04/08/2003 - 03:32
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
OK.
The configuration of my two PIXs is like this:
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ security10
enable password xxxxx encrypted
passwd yyyy encrypted
hostname --moderator edit-- firewall
domain-name teste.pt
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 101 permit ip 10.10.10.0 255.255.255.0 --moderator edit-- mm.mmm.mmm.0 255.255.255.0
access-list outside-in permit icmp any any echo
access-list outside-in permit icmp any any echo-reply
access-list outside-in permit icmp any any unreachable
access-list outside-in permit icmp any any time-exceeded
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1452
mtu inside 1452
mtu DMZ 1500
ip address outside --moderator edit-- xx.xx.xx.1 255.255.255.252
ip address inside 10.10.10.254 255.255.255.0
ip address DMZ 172.16.1.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside-in in interface outside
route outside 0.0.0.0 0.0.0.0 --moderator edit-- xx.xx.xx.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
filter activex 80 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
filter java 80 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap 10 ipsec-isakmp
crypto map mymap 10 match address 101
crypto map mymap 10 set peer 60.60.60.1
crypto map mymap 10 set transform-set myset
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 10.100.100.1 netmask 255.255.255.255 no-xauth no-co
nfig-mode
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 43200
telnet timeout 5
ssh timeout 5
terminal width 80
: end
PIX Version 6.1(4)
enable password xxxx encrypted
names
access-list out-in permit icmp any any echo
access-list out-in permit icmp any any echo-reply
access-list out-in permit tcp host 62.48.154.238 any eq 22
access-list out-in permit tcp --moderator edit-- nnn.nnn.nn.0 255.255.252.0 any eq 22
access-list out-in permit tcp 194.65.19.0 255.255.255.0 any eq 22
access-list 101 permit ip --moderator edit-- mm.mmm.mmm.0 255.255.255.0 10.10.10.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 60.60.60.1 255.255.255.252
ip address inside --moderator edit-- mm.mmm.mmm.254 255.255.255.0
pdm history enable
arp timeout 14400
nat (inside) 1 --moderator edit-- mm.mmm.mmm.0 255.255.255.0 0 0
access-group out-in in interface outside
route outside 0.0.0.0 0.0.0.0 60.60.60.2 1
floodguard enable
crypto map mymap 10 set peer --moderator edit-- xx.xx.xx.1
isakmp key ******** address --moderator edit-- xx.xx.xx.1 netmask 255.255.255.255
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 43200
telnet timeout 5
ssh timeout 5
terminal width 80
: end
The configuration of my two C807H is like this:
hostname RouterA-ADSL
enable secret WWWW
username ADSLPRIME password SRTFRD
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 10.10.10.1
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
ip address --moderator edit-- xx.xx.xx.2 255.255.255.252
ip tcp adjust-mss 1452
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username [email protected] password --moderator edit--
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 2 permit xxx.xxx.xxx.xxx
access-list 2 deny any log
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
login
stopbits 1
line vty 0 4
access-class 2 in
exec-timeout 120 0
login
scheduler max-task-time 5000
end
Today I saw that the isakmp protocol is passing in the routers but the esp protocol is not. I had put an access-list to see what kind of traffic was passing in the adsl routers and I saw that. The version of the two adsl router is: c820-y6-mz.122-8.YJ.bin.
With the PIXs I can see that the isakmp (phase 1) negotiation is happening but the next negotiation (isakmp phase 2) is not. Is at this point that this thing fails. Some one can tell me why?
xiaoj Tue, 04/08/2003 - 07:16
I don't think the configuration will work according to the given scenario. your internal network should have no problem get to the internet, that's because your pix has a default route pointed to ADSL router and your ADSl router forwards everything to the internet.
I can see that you are trying to establish IPSec tunnel between two private networks through PIX's outside interface(70.70.70.1 and 60.60.60.1), but both of your PIX has no way of reaching to the remote address nor through ADSL router.
You can either change your pix's outside interface to a global routable address if it's possible or NAT them through ADSL routers.
Hope that helps,
-Jimmy
rcapao Tue, 04/08/2003 - 07:42
That networks (60.60.60.0/32 and 70.70.70.0/32) are not the real networks. I gave this two as an example. The two networks that I have in reality are routable (they are not privet networks), that is, are networks given to me by one of the locals ISPs and in the routers and in the PIXs I can reach to them.
rcapao Tue, 04/08/2003 - 07:55
Sorry.
The two networks that a gave as a example are 60.60.60.0/30 and 70.70.70.0/30.
Correct Answer
xiaoj Tue, 04/08/2003 - 08:39
-Jimmy
rcapao Wed, 04/09/2003 - 07:45
Ok.
The problem is solved.
Thank Jimmy for your help and advise.
Rui
