04-06-2003 01:48 AM - edited 03-02-2019 06:26 AM
Hi All,
I happen to find that my eigrp metric seems not correct. The metric should not too large. even the connected interface, 192.168.1.0/24, FD is 2169856. and the subnet just connected to my normal serial port! and the bandwidth is 1544kbit and the delay is 20000 usec. so using metric=[(10000000/bandwidth)+(delay/10)], the metric should less 10000!
but the following is the output: can anybody tell me what's wrong?
sh ip eigrp topo
IP-EIGRP Topology Table for AS(1)/ID(20.20.20.20)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 1.1.1.0/24, 1 successors, FD is 2560000256
via Redistributed (2560000256/0)
P 2.2.2.0/24, 1 successors, FD is 128256
via Rconnected (128256/0)
P 3.3.3.0/24, 1 successors, FD is 2297856
via 192.168.1.2 (2297856/128256), Serial1
P 20.20.20.0/24, 1 successors, FD is 128256
P 192.168.0.0/24, 1 successors, FD is 2169856
via Rconnected (2169856/0)
P 192.168.1.0/24, 1 successors, FD is 2169856
via Connected, Serial1
Waimen
Solved! Go to Solution.
04-06-2003 08:37 AM
Unlike IGRP, EIGRP multiplies its metric by 256. If you divide that number by 256 then you are right, your metric is 8476.
Thanks.
04-06-2003 08:37 AM
Thanks.
