Warning message
Checking what patches have been applied.
Apr 7th, 2003
I have received this patch/hotfix Q300972_W2K_SP3_x86_en.EXE as was told it needs to be applied to callmanager.
How can i tell what patches have been applied CM 3.13 cluster.
Generally when you download a file from CCO and intsall there is log files associated with the install which is good.
Though when this patch is executed I cant find any output to say that it has been installed.And I want to check the patch level of this particular cluster.
There is a utility qfcheck f(with 3.3)rom memory would that tell me what windows service packs hotfixes have been applied to CM ?
kthorngr Mon, 04/07/2003 - 15:31
  • Cisco Employee,
Usually, Add/remove programs will provide a list of the hotfixes installed.
